8/19/2022 7:33 AM | |
Joined: 1/21/2013 Last visit: 2/8/2023 Posts: 1367 Rating:
Hi MaciekMdp, please check "SIMATIC WinCC Unified PC Simulation" is installed. If not, please install it. Take care about the FAQ "Which Windows functions must be activated in order to be able to install SIMATIC WinCC Unified?". Kind regards |
8/19/2022 8:44 AM | |
Joined: 8/4/2022 Last visit: 1/10/2023 Posts: 14 Rating:
I checked, "SIMATIC WinCC Unified PC Simulation" is installed, and Windows functions were also activated. |
8/19/2022 2:26 PM | |
Yoy're right, I don't have a license :( Is any possibility to run simulation without a license? |
8/19/2022 2:46 PM | |
Joined: 4/26/2012 Last visit: 2/8/2023 Posts: 1219 Rating:
The simulation software, which is completely integrated into the TIA portal, is used for this application. Depending on the installed WinCC version, "Basic Panels, Comfort Panels or PC Runtime Systems" can be simulated. A license is not required for this. LINK pg6 Attachment109748099_HMI_PLCSIM_DOC_en.pdf (53 Downloads) |
Last edited by: Jen_Moderator at: 08/22/2022 07:21:18PDF added as attachment. Obrigado. |
8/19/2022 3:04 PM | |
Did the "Start simulation" button enable? |
Obrigado. |
8/19/2022 3:11 PM | |
No, it's not avalaible. |
8/19/2022 3:32 PM | |
see if this option is enabled for you. |
Obrigado. |
