5/18/2015 5:53 PM | |
Posts: 16 Rating:
Hi again, You will find the snpashot of my pg/pc config and the HMI connection in attachment My PG/PC is ok because i can communicate with the PLC and animate tags of the PLC on watch tags table.
Thanks for support and don't hesitate to ask more information or screenshot if need ! AttachmentSnapShots.zip (686 Downloads) |
Last edited by: MarcoPolo01 at: 5/18/2015 5:56:37 PMLast edited by: MarcoPolo01 at: 5/18/2015 5:59:22 PMLast edited by: Min_Moderator at: 5/19/2015 12:59:32 PMMove Screenshots in attachment |
5/19/2015 10:43 AM | |
Joined: 8/3/2009 Last visit: 9/29/2023 Posts: 11297 Rating:
Hi everybody the simulator of S71500 (PLCSim V13) has an other Accessport asPLC Sim for S7300/400 . Please look at this FAQ there ist everything explaind: http://support.automation.siemens.com/WW/view/en/88193789 By Murof --------- If this Information helps you could use the Rate Botton |
5/19/2015 11:06 AM | |
Posts: 16 Rating:
Hi, Thank you but i don't use PLCSIM, i have a real PLC connected. That doesn't help to know information about PLCSim. Regards. |
