4/19/2012 11:41 AM | |
Posts: 739 Rating:
Hi, as first; it is not possible to adjust the Power Module; only the CU can / has to be adjusted. But any way have a look into the list manual for your CU http://support.automation.siemens.com/WW/view/de/30563628/133300 Into p0700 – p0713 & p1000, there you will find the adjustment. good luck |
