10/24/2019 9:31 AM | |
Joined: 5/8/2014 Last visit: 1/31/2023 Posts: 1 Rating:
Hi,
I am using Sinamics S120 for a third party Permanent Magnet Synchronous Motor. However, this fault keep showing up when the motor ramp down from 1800rpm to 0rpm. Please advice is there anyway to bypass the monitoring from the condition "I_act = 0 and Uq_set_1 longer than 16 ms at its limit" or anyway that can neglect this fault? Thank you. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/24/2019 13:16:28New subject after splitting |
4/1/2020 5:44 AM | |
Joined: 10/10/2018 Last visit: 11/28/2022 Posts: 2 Rating:
Hi Sir, did you managed to fix that problem? I am having similar problem. thanks in advance |
