6/27/2024 1:01 PM | |
Joined: 8/3/2009 Last visit: 9/19/2024 Posts: 13742 Rating: (1730)
Hello Graeme I have never done it but I think it should work in the same way as with WinCC Comfort/Advanced: https://support.industry.siemens.com/cs/en/view/109481157 In the newer TIA Versions you can also use Textlists in the Alarm texts: I hope it helps Bye Murof |
