6/7/2013 3:52 AM | |
Posts: 2 Rating: (0) |
hello lahodal, This is because the serial data buffer is too small, You need to determine the total length of the data, and read the serial data multiple times. Or split file into multiple small files, read multiple times, and then combine them. regards. ----------------------------------------- Awavo serial port monitor |
