9/22/2020 10:57 AM | |
Joined: 4/28/2015 Last visit: 9/20/2022 Posts: 1278 Rating: (300) |
Hi, I just know the fault list is available in .xml format (for each firmware on the firmware download page). For example here the alarm list for S120 FW5.2 SP3 HF1: https://support.industry.siemens.com/cs/hu/en/view/109780844 If you need the texts for your HMI display you could use this application example with the xml parser: |
Best regards, |
Joined: 6/19/2019 Last visit: 10/14/2024 Posts: 700 Rating: (74) |
If i good understand you can find here |
9/22/2020 10:58 AM | |
Joined: 5/12/2006 Last visit: 10/16/2024 Posts: 22414 Rating: (3018)
i only know it as XML File https://support.industry.siemens.com/cs/at/en/view/109762626 |
9/22/2020 11:03 AM | |
Joined: 8/31/2005 Last visit: 8/20/2024 Posts: 2198 Rating: (328) |
On the web pages with the SINAMICS firmware (e.g. https://support.industry.siemens.com/cs/hu/en/view/109780844) you can download an alarm list (in XML format). With the "Parser" (https://support.industry.siemens.com/cs/ww/en/view/77467239) you can convert the XML file(s) into Excel file(s) (CSV format). |
8/4/2021 5:21 PM | |
Joined: 1/4/2013 Last visit: 10/15/2024 Posts: 1127 Rating: (102) |
I dig out this old thread because I got the same problem, but I think that the solution that is proposed is too laborious and, in my case, it inserted some special characters in the alarm lists that ruined the entire work. It is strange but people need xlsx and Siemens gives XML and tells you to parse it. Wouldn't it be more simpler to post directly the xlsx file ? Here is the text list in xlsx, I hope it will be helpful for any1. AttachmentS120_4 4_Complete_IT_EN_DEU_FR_ES.xlsx (440 Downloads) |
Searching for Siemens used/new equipments ? |
