6/9/2016 7:05 PM | |
Posts: 1 Rating: (0) |
My problem with Sinamics DCM 6RA8075 is following: after switched on power supply first LED lamp on CUD is RED and on BOP has nothing. Can anyone help with this? ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 6/10/2016 1:42:55 PMNew subject after splitting |
6/9/2016 8:16 PM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating: (878) |
Please check the attached sheet which explains CUD LED status significance at different state. Please check which LED lit or flashes. Have you removed or inserted memory card during power ON or running condition? Have you checked electronic power supply? HTH Attachment6RA80 CUD LED Status .pdf (763 Downloads) |
