9/1/2013 6:03 PM | |
Joined: 5/12/2006 Last visit: 4/23/2024 Posts: 22224 Rating: (2979)
Hi, this connection is correct, you don't need an additional switch. regards Christoph |
9/1/2013 8:43 PM | |
Hello, which ethernet cable do you use? The connector is designed für industrial ethernet cables like 6XV1878-2A . In the cable there must be 4 pairs of whires! But for PN you should use the 2x2 cables and connectore because PROFINET is limited to 100Mbit ! Regards Christoph |
9/2/2013 2:11 PM | |
Posts: 47 Rating: (0) |
My ethernet cable is6XV1850-0AH10 It has for wires.one set is white-blue & other set is white-orange.
9/2/2013 2:33 PM | |
Thanx for ur reply. Can I use CAT5 cable for my ethernet communication with that connector
