11/29/2016 5:35 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872) |
Hello, r0046.21 is STOP2 internal enable missing signal. Please refer the attached sheet for more detailed information. AttachmentSTOP2 internal enable missing.pdf (1925 Downloads) |
11/29/2016 7:15 AM | |
Posts: 3 Rating: (0) |
Thank you for reply. No, for G120 r0046.21 is PU enable signal. Attachmentmissing signals.pdf (846 Downloads) |
11/29/2016 7:40 AM | |
OK. Please refer the attached sheet which explains how PU missing signal is internally generated. HTH. |
11/29/2016 8:24 AM | |
I'v just found the reason of this fault. Here it is. |
11/29/2016 9:06 AM | |
Posts: 1529 Rating: (202) |
That certainly may give you a PU error. |
