4/28/2007 5:26 PM | |
Posts: 1 Rating: (0) |
Hello, i have to commission s120 with PM340 and CU310DP for a two axis positioning control. The siemens documentation talks about positioning telegrams: standard telegram 7 and siemens telegram 110. My problem is that i couldn't find the gsd file with these telegrams. I looked at this link given in the siemens documentation http://support.automation.siemens.com/WW/view/de/113204. The gsd file si0280e5 has a date 09/05 and documentation is earlier. Do you know where i could find it. Thank you for your help |
5/2/2007 10:24 PM | |
Posts: 26 Rating: (3) |
Maybe this will help you, We have some problems too with profibus, But this GSD file I haven't test myself yet, I've found it by lookingin a firmware upgrade zip-file. hope it will do the trick for you ( and for us ) AttachmentGSD-files Sinamics S120.zip (2651 Downloads) |
12/4/2007 1:07 PM | |
Good.Thank you! |
12/9/2011 5:37 PM | |
Many thanks !!! Russia. |
