7/4/2014 9:46 AM | |
Joined: 10/11/2006 Last visit: 9/18/2024 Posts: 5906 Rating: (804)
Hello, yes that is possible, see capture 7.7.5: http://support.automation.siemens.com/WW/view/de/68042590/0/en |
With best regards, |
7/12/2014 2:24 PM | |
Hello, with that method you can only use one measuring probe at the same time. http://support.automation.siemens.com/WW/view/en/54992004 Or if you can split your encoder to two SMC and configure a second drive object, then you have two independent position evaluations. Or you use SIMOTION. |
