4/26/2022 11:07 AM | |
Joined: 11/4/2011 Last visit: 12/19/2022 Posts: 157 Rating:
ErrorID800C with ErrorInfo 003E means "PROFIdrive: Drive on bus failed (station failure). See here: https://support.industry.siemens.com/cs/de/en/view/109773400/127246958091 As stated by another user before: Once the issue occurs again, check the drive for further error messages from this point in time, then depending on what you find there continue. To me it seems the TO is not the cause, but the drive. Regards, |
4/27/2022 10:11 AM | |
Joined: 2/10/2020 Last visit: 9/16/2022 Posts: 47 Rating:
Here is 2 info about problems but not konw more info of last time. |
4/27/2022 10:50 AM | |
only this block say info about problem.look to atttachament. |
4/27/2022 10:51 AM | |
Im sory but not understant. Wher I can check info of motor? |
