1/29/2020 1:42 AM | |
Joined: 4/3/2019 Last visit: 12/9/2024 Posts: 4 Rating: (0) |
Hi ab1992, Have you found the solution ? |
1/29/2020 8:30 AM | |
Joined: 4/28/2015 Last visit: 10/22/2024 Posts: 1278 Rating: (300) |
Please also check this FAQ. Always when I read about problems with STO and V90 I am quite sure this will help. Be aware of the control of hardwired STO -> your F-DO might do sporadic dark test which needs to be disabled. |
Best regards, |
7/9/2020 8:35 PM | |
Joined: 7/20/2009 Last visit: 1/16/2024 Posts: 61 Rating: (3) |
Have anyone found the solution ??? |
3/10/2021 2:29 PM | |
Joined: 8/31/2015 Last visit: 3/12/2024 Posts: 1 Rating: (0) |
I am also having the same problem. No solution till now.... |
1/11/2024 11:29 AM | |
Joined: 4/1/2022 Last visit: 10/4/2024 Posts: 2 Rating: (0) |
Same problem here, no found solution, siemens ._. |
1/12/2024 8:42 AM | |
Joined: 6/27/2017 Last visit: 6/26/2024 Posts: 158 Rating: (21) |
Hello, did someone start a Support Request and asked Siemens directly? If not, please start a support request to get a solution and if you want that everyone has a benefit from it: please share the answer from the support. P.S.: I hope you have read the forum rules and know that this is just a platform where users support each other and Siemens is not obliged to answer here.. |
