7/21/2022 5:29 AM | |
Joined: 5/12/2006 Last visit: 12/4/2024 Posts: 22472 Rating: (3035)
should be possible to update to V1.11.03 https://support.industry.siemens.com/cs/ww/en/view/109746211 The motordata base is coded in the FW/V-Assist and can not modified manually. You should also use the Latest V-Assist V1.07.02 https://support.industry.siemens.com/cs/ww/en/view/109738387 |
7/22/2022 8:50 AM | |
also use newer v-assistant? |
7/22/2022 8:58 AM | |
Joined: 11/30/2015 Last visit: 11/14/2024 Posts: 18 Rating: (0) |
V1.07 |
7/25/2022 8:34 AM | |
Joined: 12/16/2021 Last visit: 8/22/2023 Posts: 126 Rating: (2) |
Hi Lucasm, Please check latest version SINAMICS V-ASSISTANT V1.07.02 Thanks
Last edited by: Jen_Moderator at: 07/25/2022 13:48:56Link optimized. If The Information Helpful, Then Don't Forget Give (To thank ) and Rate It |
7/25/2022 7:44 PM | |
Hi Jack, I am using V1.07, but the motor is not listed there. Regards Lucas |
7/25/2022 8:02 PM | |
V01.07 is a ioncomplete information please use the exact versiopn you use! |
