3/5/2018 8:51 AM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, I've found this example about VPN connection with Sinema Server. Maybe also other additional info links can be helpful to you. |
With best regards... |
3/8/2018 9:17 AM | |
Posts: 1368 Rating:
Hello, can you post a simple grafik of your constellation? Your Client are: ==>Field PG with SINEMA RC Client You want to reach from Field PG (STEP 7), the network behind Worker PC over VPN tunnel. If you want to reach a client from a client, you should work with fixed ip addresses (see tab "vpn connection mode" in SINEMA RC Server Webbased...) Look here:https://support.industry.siemens.com/cs/de/de/view/109746841 |
