12/31/2013 3:21 PM | |
Hello, The popup seems to tell that you do not have a valid installation of Java on your PG. Connect you PG to Internet. Go to a link to download and install java (for instance: http://java.com/en/download/index.jsp) The first time you will run the topolgy, you will get a new popup asking if you trust the called jaca applet. Answer with "trust always ..." |
Best regards |
3/2/2017 12:50 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by sanj1508 is split to a separate thread with the subject Sinema Server V12 Error. Best regards |
