10/14/2013 12:16 PM | |
Posts: 5 Rating:
ThanksEkalavya. After 3 hours of thorough searching, i found the toolbox cd. Now i have installed toolbox. I nevigate to the mentioned folder and found cycle files. I am newbie in cnc field and i don't know what to do now to get back cycle file in cnc milling machine. Please guide me step by step. Regards Gohar |
10/14/2013 5:04 PM | |
Posts: 2964 Rating:
Hello, You are in the right folder here you find mill folder open this you find the cycles. LCYC60.SPF Row of holes LYCY61.SPF Circle of holes LCYC75.SPF Rectangular,circular pocket and slot LCYC82.SPF Drilling countersinking LCYC83.SPF Deep hole drilling LCYC840.SPF Tapping with compensating chuck LCYC84.SPF Tapping without compensating chuck LCYC85.SPF Bore 1 LCYCLESM.SPF additional file for milling cycles LCYCMILL.SPF Archive of all milling cycles You can use LCYCMILL.spf all the cycles will get loaded / if you want to load separately you can load it individually. You need to have a wincpcin tool for loading this and RS232 cable for connecting to your laptop and the machine. Send the data from your laptop and receive the data ensure you keep the proper settings like baudrate and on the cnc side switch on the plc. Check it out and revert back. Regards, Prakash |
10/14/2013 5:19 PM | |
Posts: 5 Rating:
ThanksEkalavya You are very informative. Tell me about baudrate. and how to transfer LCYCMILL.spf with winpcin??? Sipmly connect machine with laptop and send file with winpcin??? In which folder or place the cycle file should transferred in the machine??? Machine remains on during transferring or should it be off??? |
10/15/2013 6:21 AM | |
Posts: 2964 Rating:
Hello, You can look in to this attachment.. also you see more informations in the DOCON WEB LINK https://www.automation.siemens.com/doconweb/content.asp?item=11851&cd=sinumerik_simodrive_04_2010_e&scope=all Regards, Prakash Attachment802C base line .pdf (241 Downloads) |
