5/20/2012 4:19 AM | |
Posts: 2964 Rating:
Hello. Are you plugging the cable at the front side ? try plugging it at back side and check? reduce your baudrate and check Regards, Prakash |
5/20/2012 12:39 PM | |
Posts: 3 Rating:
Thanks for the tips guys. I have tried plugging into the front and the back of the controller. I will have a crack with the lower baud rate and see how it goes. |
3/28/2014 9:43 AM | |
Posts: 3 Rating:
Could you find the solution. We have the same problem |
