11/28/2010 6:33 PM | |
Posts: 2964 Rating:
Hello... Looks like NC-PLC backup is not present.... Could you try loading the same and check? Regards, Ekalavya |
1/30/2011 10:35 AM | |
Posts: 2964 Rating:
Hello.... What is indication on the I/R module? if it indicatesgreen....module is not healthy 63/64/48 missing... What is the indication on CCU card does it display 6 on it? You can disconnect the I/R module switch on alone and check first whether it healthy first... attaching you the link for the same... /tf/WW/en/Posts/45447#top hope this will help you out... Regards, Ekalavya |
1/30/2011 12:18 PM | |
Posts: 3 Rating:
Hello, On the I/R module the green led is on and in the CCU's modul 6 is displayed on it. |
1/31/2011 5:23 AM | |
Posts: 2964 Rating:
Hi.... Looks like I/R module is not in healthy sign ...Check enbales(63 / 64 / 48) in addtion to this kindly check the (112,NS1-NS2) Regards, Ekalavya |
