12/16/2010 9:08 AM | |
Joined: 9/18/2006 Last visit: 1/22/2025 Posts: 595 Rating:
Hi. Sinumerik 828 has no interface profibus. The system uses the interface profinet. Best regards. Attachmentinterfaces.pdf (206 Downloads) |
12/16/2010 9:29 AM | |
Joined: 4/18/2010 Last visit: 1/2/2025 Posts: 65 Rating:
Thanks alot. And what about the Sinumerik 828 order catalog, do you know where it could be found in English? Best Regards
12/16/2010 2:49 PM | |
Posts: 2964 Rating:
Hello.... You can get in touch with your local Siemens office loacted in your region..... Check out this link https://www.automation.siemens.com/mcms/infocenter/content/en/Pages/order_form.aspx?nodeKey=key_9178615&infotype=1 Regards, Ekalavya |
12/17/2010 9:33 PM | |
Unfortunately, we don't have a sales agent in our region. The page that you have mention does not contain any order catalog. After googling a lot I found that there is only aChineseversion available for download :http://www2.ad.siemens.com.cn/download/Upload/MC/catalog/5043[1].pdf The strange thing is that there is nothing available in English ! From the file, I found that although 828D supports both SMC20 and SMC30 modules but it does not support SSI encoder evaluation. Does any one confirm it ? Thanks |
12/18/2010 4:55 AM | |
Posts: 2964 Rating:
Hello.... Iwill check it up for english.....SMC30 only supports for SSI.... Regards, Ekalavya |
1/12/2011 4:28 PM | |
Dear Ekalavya, In the mentioned catalog, the SSI encoder evaluation for 828D is unavailable. Do you confirm ? Thanks |
1/13/2011 3:38 AM | |
Posts: 2964 Rating:
Hi.... Need to be checked but SSI encoder normally supported by SMC 30 only as i now.... 828D document there is SMC 30 information. http://www.automation.siemens.com/doconweb/content.asp?item=10575&cd=sinumerik_sinamics_04_2010_e&scope=all Regards, Ekalavya |
12/20/2016 4:10 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by Petukhov1981 is split to a separate thread with the subject Use 828D in new project with SSI absolutely encoders. Best regards |
