6/18/2012 11:07 AM | |
Joined: 3/25/2012 Last visit: 2/21/2022 Posts: 8 Rating:
Hello i have solved my problem. Thank you SteveA you helped me a lot to find where my cycles and data are stored. After some time watching changes of data in _OVR i decided to take a look at the Cycle 977 itself and i found out that at it has this line _OVR[2]=0 and i replaced it with this one _OVR[2]=_M_MSPE[6] and now my data stays writen in _OVR[2] where i can use it. Finaly everything is working right except my calculation for table rotation. I have tried it yesterday for the first time and calculated rotation for C axis seems to be accurate only when the part is clamped at the center of the table which is rearly a case in my setups becouse of part geometry. So after all this trouble i am stuck again I have uploaded my program if someone can help I came so close and now i cant use it AttachmentMeasuring.zip (98 Downloads) |
