10/7/2011 12:38 PM | |
Posts: 2964 Rating:
Hello.... I think your using TIA (Totally Integrated Automation)....it is not possible....WinCC Flexible 2008 is normally used for developing custom screen in 840D connected with PCU50.... Check this PDF...may be useful.... Regards, Prakash AttachmentHMI_Projpaket_WinCC_e_110825.pdf (436 Downloads) |
10/7/2011 1:16 PM | |
Posts: 3 Rating:
Strange, the document for sinumerik operate wincc tia portal was available up until this morning through siemens, now its not there any more.. i did save it however. attaching it. anyway, which document describes how intercom between plc <> cnc works? found some post where they use $A_DBB[9] and so on to read from plc, also read in some forum that u can use H functions, say H = 200 to set a variable to 200 in the plc. Examples of this would be really helpful.
AttachmentSINUMERIK Operate WinCCenUS_en-US.pdf (442 Downloads) |
10/7/2011 1:38 PM | |
Posts: 2964 Rating:
Hello... Thanks for the document..... it is nice.... if i understand clearly you need interface signals betweenPLC and NCK right ???? check this information in DOCON WEB.... https://www.automation.siemens.com/doconweb/content.asp?item=6013&cd=sinumerik_simodrive_04_2010_e&scope=all Regards, Prakash |
10/8/2011 7:41 AM | |
Posts: 2964 Rating:
Hello.... Check this link you may find it useful..... Simatic Infos.... /tf/WW/en/Posts/54814#top Reading and writing R parameter /tf/WW/en/Posts/50938#top Regards, Prakash |
