2/20/2023 8:01 AM | |
Joined: 4/8/2021 Last visit: 8/6/2024 Posts: 638 Rating: (104) |
Hi I used the same setup (UPS1600 + UPS1100) once and everything worked correctly. I believe the information you saw in the manual reffers to the UPS1600 with Ethernet/USB interfaces (different MLFB), that can be also monitored using the SITOP UPS Manager software. This is the manual I used then. https://support.industry.siemens.com/cs/ww/en/view/84977415/142086811915 Hope it helps. Best regards. |
