5/23/2011 2:15 PM | |
Joined: 3/21/2006 Last visit: 12/2/2024 Posts: 10229 Rating: (1181) |
Hello, You need 4-20mA loop power. Means from AI (4-20mA) this device will receive 24VDC like power for it and on the same 2 wires you will read 4-20mA process signal. If you still have a troubles give the MLFB of AI card to assign where is the (+) and (-) there. Briefly you need AI (4-20mA assigned) with 2 wire connection transmitter...
Best regards, Hristo Mihalev |
5/23/2011 2:23 PM | |
Posts: 47 Rating: (1) |
UMEN...thanks! I thought it must be this way, but the book is a bit confusing. |
5/27/2011 10:19 PM | |
Joined: 5/28/2008 Last visit: 12/7/2024 Posts: 4516 Rating: (840) |
Hello TechnoDude, A part from wiring issue, I think the next step for you is to configure the LR560. I believe that these videos is useful for you Hope this helps.
