1/2/2016 11:01 AM | |
Joined: 11/29/2011 Last visit: 8/24/2023 Posts: 1347 Rating:
Hi, In this example you can see how to do it with PCS7: Gravimetric level measurement with SIWAREX U in the PCS 7 environment Note: Check for applicability under chapter "2.1 Requirements" or maybe contact your local Siemens Representative. I hope I could help! |
- What you read here, please check with manuals and your requirements. |
4/29/2016 1:06 PM | |
Joined: 1/4/2007 Last visit: 9/28/2023 Posts: 1061 Rating:
Hello sherief, Your client shall use one of the Getting Started projects (depending on his software: Simatic Manager or TIA Portal): Afterwards he needs to define the parameters of the DR3 into the DB_Scale (e.g. DBW58: adjustment weight). After that execute the command “Adjustment zero valid” when the scale is empty: After that put the adjustment weight on the scale and execute the command “Adjustment weight valid”:
