8/24/2010 4:32 PM | |
Posts: 5 Rating:
Hello Siwarexi, My load cells are 2 mV/V, and I am using0 for off set. 3 load cells of 10t each. I did the " theor. calibation" but I am still having diference. If I put 500 kg I get 530kg, and if I put 1000kg I get 1060. I did not find a way to do a fine adjustment. Do you have any ideia? Attached is te CS file I am using. Thanks. AttachmentALBUNKER.zip (70 Downloads) |
