8/5/2009 5:18 PM | |
Posts: 8 Rating: (0) |
Good Morning, i have some problem with startup of siwarex-cs. I have installed the module and for manipolation of data i have used the sample program downloaded from Siemens Support. The program is show in attached file SIWA00. I have used also winnCC example included in the Getting_Started_CS for try to configure the module. The FB give me the FB_ERR_CODE = 2 but i can't understand where is the problem. The online data of FB is show in SIWA01 picture attached. Can someone help me to find the problem? Thank a lot. AttachmentSIWA01.pdf (389 Downloads) |
9/14/2009 9:08 AM | |
Good Morning Siwarexi, i had test the configuration with DPV1 as you told me and always seem to be good. Thank's a lot for the information. Have a nice day. |
