4/20/2017 9:24 AM | |
Posts: 23 Rating: (0) |
HI Sir, Please help me, Siwarex FTC Loss in weight i use PID Controller. what you calculate weighing signal from Gross Weight or Net Weight ? |
4/20/2017 11:14 AM | |
Joined: 1/4/2007 Last visit: 12/5/2024 Posts: 1153 Rating: (175)
Hello tomkrub27, On the internet you can find the Quick Guide how to do the commissioning with the Siwatool software: https://support.industry.siemens.com/cs/ww/en/view/80867611 To your question: You can use either the Gross weight or the Net weight to calculate the decreasing of the weight. It's the same result. But it is not necessary that you use the PID-controller and the Gross weight or the Net weight. The FTC Loss in weight handles the calculation itself. You need only to contact a freqeuncy converter to the Analogue Output of the FTC module. Best regards Siwarexi |
4/28/2017 1:52 PM | |
Joined: 1/18/2017 Last visit: 10/1/2024 Posts: 4 Rating: (0) |
Siwarexi's post is useful and it will work too... |
