12/13/2013 4:05 PM | |
Posts: 206 Rating:
Hello zaid_b, the problem you might come from the mechanical constrution and the temperatur change together. If the mechanical construction is OK the signal change should be unside the error limits of this lod cell. The error limits you find in the data sheet. If you need support with this you can open a support request http://support.automation.siemens.com/WW/view/en/38716036 they will help you. Helpfull for a diagnose are stetches, pichtures, exact data of the load cells and used mounting units... Regards ABenno |
