1/7/2019 9:33 AM | |
Posts: 206 Rating:
Hi OMKRIS, I suppose you mean the Siwarex U one channel 7MH4950-1AA01!? You can access all parameters of the Siwarex U via S7-Program, therefore you just need to use the getting started example that you find here: https://support.industry.siemens.com/cs/ww/en/view/28391777 . You also have the possibility to connect via RS232 direct to the Siwarex U, for this you need a software that is called Siwatool, the Siwatoo you can by with order no. 7MH4900-1AK01. You have to connect directly to terminals at the terminal block of the Siwarex U, more about that you find in the manual https://support.industry.siemens.com/cs/ww/en/view/28392477 chapter 4.4.7. Regards ABenno |
