4/20/2020 11:41 AM | |
Joined: 1/4/2007 Last visit: 9/28/2023 Posts: 1061 Rating:
Hello Mianhamzahhhh, On the internet, you can find an TIA Portal example project with a 1214C-PLC: Attached you can find the procedure for the calibration with the Siwatool software. „… change MB ADD PTR in modbus connection on runtime …“? Normally the internal totalizers are used of the Siwarex WP241 module. Best regards Siwarexi AttachmentFAQS_WP241_Siwatool_Calibrate_en_V1.pdf (69 Downloads) |
