10/18/2010 10:29 AM | |
Posts: 22 Rating:
Hello, I use Sizer to config a 6 axises simotion system, when I choose "Camming" or "Gearing", it's display error(see the attached "error1".jpg), and I seek the help, it's display "All follow axes are leading axes and all kinematics models are assigned the requied number of axes". (see the attached "error2".jpg), Could you please help to sovle way? Attachmentsizer.zip (379 Downloads) |
10/18/2010 11:40 AM | |
Posts: 116 Rating:
Hi, you must select a master axis for each synchr. axis. For this, use a real or virtual positioning axis. Regard Jerry |
10/18/2010 3:56 PM | |
Posts: 22 Rating:
Thanks, follow your advise, I make the right way. |
