10/11/2019 9:39 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello K.T. Which WInCC Do you use exactly (WinCC Professional RT or WinCC Advanced RT)?? -> if you use Professional RT then it could also be a Problem with .Net Framework; look at this: https://support.industry.siemens.com/cs/ch/en/view/109749283 If you have a Screen Item that is outside the screen (also if only with one pixel) then you will get a warning while compiling. Bye Murof |
