7/27/2016 3:12 PM | |
Joined: 6/3/2014 Last visit: 1/17/2023 Posts: 660 Rating:
Hello DennisA, which TIA Portal / WinCC Version do you use? Did you activate "Properties > Style/Designs >Style/Design settings" and deactivated it later? Or do you have "Dark default values" selected in "Toolbox > Options"? In this case the option is greyed out. If you add a slider when "Classic default values" is selected, then all options are availiable. What can you do? You could change the style and add another slider besides the default one:
More informations on using styles:
