10/3/2011 11:14 PM | |
Posts: 59 Rating: (0) |
the module is SM 1222 16 DO / RLY |
10/4/2011 7:55 AM | |
Joined: 4/22/2010 Last visit: 1/15/2025 Posts: 5697 Rating: (715) |
Hello, You canfind the connection diagram here: http://support.automation.siemens.com/WW/view/en/39710145 Page 236. Regards, Marcjan |
Problem solved? |
10/18/2011 11:08 AM | |
Posts: 37 Rating: (2) |
Hi You check the 0VDC is properly connected. Even after the output LED is not lighting up means this could be a component problem....
