10/25/2012 2:05 PM | |
Joined: 4/24/2006 Last visit: 12/1/2023 Posts: 8596 Rating:
Hello Bryll, Perhaps the following links might help: What should you watch out with regard to licenses for WinCC flexible and panels? how can you transfer licenses to an operator device with the ALM without WinCC flexible being installed? It looks like license is not on panel You can also have a look at this link: how can you recover defective licenses and authorizations? Best regards, Wizard |
10/25/2012 2:12 PM | |
Posts: 3037 Rating:
Hello Bryll, You can retrieve your lost licence key. see the chapter 6.5. What should you watch out with regard to licenses for WinCC flexible and panels? You start a support requestto the customer support. Tweety |
12/3/2014 12:13 PM | |
Joined: 9/1/2005 Last visit: 8/24/2023 Posts: 4099 Rating:
follow up question published by salrandazzois split to a seperate thread with the subjectTP700 connect it via Automation Manager. Best regards CS Moderator |
