10/22/2012 12:44 AM | |
Joined: 7/2/2008 Last visit: 9/27/2023 Posts: 928 Rating:
HelloTomy Master The answer is no and I believe this is for a good reason. It lets you free to order either screw or spring front connectors. One other good idea is that you can order modules as spare parts and in this case you don't need the front connectors. You should be careful when you order them. I'm sure you know that some modules require 40 pin front connector and others require 20 pin front connector. Best regards, H-H
