4/17/2020 4:39 PM | |
Joined: 9/27/2006 Last visit: 7/7/2022 Posts: 11744 Rating:
Hello Charles-Benoît; Fos a good description of the smoothing parameter and the effects of its filtering functions, you could read snoop3014's posts in the following threads: https://support.industry.siemens.com/tf//ww/en/posts/s7-1200-analog-module/184920?page=0&pageSize=10 The only thing I can think of is that using 32 samples per calculation (strong smoothing) on a pressure signal (that has a tendency to vary quickly) might take too much time for your process. Did you try setting a medium smoothing parameter? How does the AI signal respond? Hope this helps, Daniel Chartier |
