6/10/2008 8:28 AM | |
Joined: 9/23/2005 Last visit: 6/2/2023 Posts: 4175 Rating:
Hi, basically the module supplies number of "pulses". If the encoder SSI frame is Gray and consist only of position value then it can be converted directly to natural binary in the module (when you set encoder type - Gray). Otherwise you should select binary and strip position info out of the SSI frame in the program and do conversion Gray->natural by yourself. More info you can find in this manual. |
Regards, |
