9/27/2019 11:46 AM | |
Posts: 8 Rating:
Hello, Can you explain further? I would like to use the following code: string1 = "Variable name from DB with UDint variable" OtherVariable = SmartTags(string1) or x = 1 OEE_DB_lijstgrootsten(x - 1) = SmartTags("L_IO_L_" & x &".Motor.OEE.Total_Net_result") how would i need to implement your code to make mine work?: If VarType(TagAsString) > 0 then NoOp = 0 End If SmartTags(TagsAsString) = Value Greetings, Jurjen ------------------------------------------------------------------------------------------ |
Last edited by: jurjen120 at: 09/27/2019 12:17:33Last edited by: jurjen120 at: 09/27/2019 12:18:26Last edited by: The Helping Hand at: 10/04/2019 10:18:31New subject after splitting |
