6/1/2017 12:04 PM | |
Joined: 6/26/2013 Last visit: 10/19/2024 Posts: 143 Rating:
Hello Whoppertje, I tried your loop and it worked fine for me. My guess is there must be an addressing issue in Tags or DB. Please confirm and share if possible. We may be able to debug better then. If it helps, you may use rate button. |
meeda_ |
6/2/2017 1:45 PM | |
Hello Whoppertje I noticed something now using S7315-2DP and WinCC TIA V13 SP1:
I configured TP1200 Comfort and connected its simulation with the PLC via PC Adapter(MPI). Perhaps the experts can confirm and explain?? If it helps, you may use rate button. |
