12/29/2016 7:41 AM | |
Joined: 10/30/2012 Last visit: 6/24/2024 Posts: 73 Rating:
Hello. I am trying to access the interfaces (port states: ifOperStatus) of SCALANCE XR324-12M fw 4.0.4 with SNMP. Manuals on the topic: SNMP OPC Profile SCALANCE X-300 Industrial Ethernet Switches SCALANCE X-300 / X-400 These manuals suggest I need to use the following address for accessing ports ifOperStatus property for XR324-12M: Port 1.1: 1.3.6.1.2.1.2.2.1.8.51380225 The problem is when I try to communicate by UDP, I get an error 16#8103 (noSuchName >>>>The MIB object does not exist ->SNMP_OID_NOT_EXIST). How do I access the port status? |
12/29/2016 10:10 AM | |
Hello, Anyway, I would recommend the following general approach. This method allows you to find out what is the correct OID for a given topic. |
Best regards |
