9/15/2010 10:06 AM | |
Posts: 467 Rating:
hello Ahmed, ....attached a description, how a slip-ring motor has to be started via Softstarter (= Sikostart). I assume, that the used resistance in the rotor circuit is not correct dimensioned to allow a proper startvia Softstarter, when the gear box is coupled. You will have to use a resistor with higher resistance. But that cannot be calculated, you have to find it out by some tests.
kind regards LesPaul Attachmentslipring.pdf (301 Downloads) |
