11/10/2014 4:01 AM | |
Joined: 5/12/2006 Last visit: 1/27/2023 Posts: 21197 Rating:
Hi, For a Upgrade to CU320-2 DP you need a new CF Card and a new FW V4.x A Update to FW V2.4 is possible. You must only chance the FW on the CF Card to FW V2.4. But notice that this FW is no longer supported by SIEMENS ! Regards Christoph |
11/10/2014 5:23 AM | |
Hello, for a CU320 the Latest FW is V2.6 SP2 HF19. The problem with the r32 parameter can be that the AOP Verison ist not compatible with the FW Version of you CU. If you work with older FW on a new AOP you must downgrade the AOP Database and AOP FW. You should contact your local siemens Support to get the relevant data for a downgrade. Regards Christoph |
