10/27/2021 6:58 PM | |
Posts: 257 Rating:
Hello SIOS Forum Community, in connection with software redundancy, customers ask us again and again which connection can be used to couple the CPUs. You can use S7-300 CPUs and S7-400 CPUs for software redundancy. The following connection types can be used to connect the CPUs for redundancy coupling:
A complete release list can be found at: https://support.industry.siemens.com/cs/ww/en/view/42614519 Due to the switching speed, we would always recommend an Ethernet coupling. This shortens the time during which the outputs remain quasi-frozen when switching over. Best regards, SIMATIC International Technical Support Hub |
10/28/2021 6:49 AM | |
Joined: 10/7/2005 Last visit: 3/26/2023 Posts: 2962 Rating:
Are you sure about usage of "integrated interfaces of the CPU's" for item 2 and 3? Afaik, a CP is required for this. |
Cheers |
