9/5/2012 3:24 PM | |
Joined: 8/18/2009 Last visit: 8/7/2023 Posts: 537 Rating:
Dear Expert, I have prepared one programm but in this software rendundancy is not established... means CPU changeover but machine is stop after changeover... what is missing in programm ( I have attached)please tell..
Attachment20120827_CPU.zip (41 Downloads) |
Rajkiran Patil |
9/13/2012 10:47 AM | |
Joined: 9/6/2008 Last visit: 5/7/2022 Posts: 1121 Rating:
Hi Well you have used S5 timers in your program go to FC3, in CPU A T5 and T6 have been used In the Soft redudant system you should not use S5 timers You can use IEC timers only. Furthermore you have used memory areas with gap inbetween Please understand that you can not use memeory areas with gap in between. It should be continous value. It is recommended to use Shared DB value. See attached file for software redudancy Have fun... AttachmentSWR_MANUAL.pdf (37 Downloads) |
Jazz |
