4/19/2020 9:07 PM | |
Joined: 9/21/2016 Last visit: 4/10/2022 Posts: 14 Rating:
I WANT SOFTWARE TO CONNECT SINAMIC SINGLE MOTOR MODULE 85 A WITH PC , ORDER NO. 1P 6SL3120-1TE28-5AA3 ,WE ARE FACING PROBLEM IN INVERTER , ------------------------------------------------------------------------------------------ |
Last edited by: Pradip123# at: 04/19/2020 21:10:49Last edited by: Jen_Moderator at: 04/20/2020 13:07:17New subject after splitting |
4/19/2020 10:58 PM | |
Joined: 9/27/2006 Last visit: 2/3/2023 Posts: 11949 Rating:
Hello Pradip; Are you working with TIA Portal programming software? In that case you can use Startdrive as a commissioning tool for the S120: SINAMICS S120 Commissioning Manual with Startdrive https://support.industry.siemens.com/cs/ww/en/view/109771818 Startdrive follows the version history of your Step 7 v1x software. Here is the download link for Startdricve v15.1, associated with TIA POrtal v15.1. If your version of Step 7 TIA Portal is different, use the Search box at the right of this page, using Startdrive v1_ as a search term, to locate the download files. SINAMICS Startdrive V15.1 (Download) https://support.industry.siemens.com/cs/ww/en/view/109760845 Hope this helps, Daniel Chartier |
