12/8/2010 12:34 AM | |
Posts: 76 Rating:
Hello someone could raise as connects a source of 24 vdc, and that points db9, NCU assembly required to amend mistakes and I do not want to spoil anything because my client has no spare hand. thanks in advance Splitted from PC Adaptor (USB + Serial) 24V Supply Sinumerik MPI. |
12/9/2010 12:05 AM | |
Posts: 76 Rating:
could provide the wiring diagram with an external source of 24 VDC. even a drawing to ... thanks in advance |
12/9/2010 1:47 PM | |
Posts: 2964 Rating:
Hi... Pin no 2 (M24v supply) Pin no 7 (P24V Supply) Attaching you the PDF of the same check it out..... this document is already there in our fourm Regards, Ekalavya AttachmentPC_Adapter_USB_e[1].pdf (48 Downloads) |
