2/7/2012 2:27 PM | |
Joined: 4/24/2006 Last visit: 9/14/2023 Posts: 8592 Rating:
Hello Tomy Master, The SP2 contains SP1, so you can directly install SP2. See this link: Service Pack 2 for STEP 7 V11 When you want to install SP2, you need V11 or V11 + SP1 Best regards, Wizard |
2/7/2012 4:01 PM | |
Joined: 8/31/2010 Last visit: 9/21/2023 Posts: 1499 Rating:
Hello Tomy Master, This is applicable for WinCC v11 also, either you need WinCC v11 or v11 with SP1 as a prerequisite for installing WinCC v11 SP2 Service Pack 2 for WinCC V11 |
Like it? Rate it! |
2/7/2012 9:57 PM | |
Joined: 3/21/2006 Last visit: 7/12/2023 Posts: 10221 Rating:
What about to install SP2 like a separate installation? |
2/8/2012 8:05 AM | |
In order do not repeate the procedure in forum for that will send you a PM. OK, let's try it on German - Tia-Portal SP2 installieren Best regards, Hristo Mihalev |
